Variable value access on the Service Engine Client can lead to an increase in memory consumption in the zennetsrv.exe process
Generic variable value access (from zenon Process Gateway or other component) on a zenon network client may cause an increase of the allocated memory of zenon Network service (zenNetSrv.exe). The issue has been addressed and the memory consumption has been improved.
Item ID: 292632
Version: 14.00 Build: 342340
