Variable in CEL not correct when using eSignature in Multiproject
In an integration project, wrong variables are written to the CEL when using eSignature. Integration project and subproject have variables with the same names. When signing an operator action, the variable from the other project is entered in the CEL.
This behavior has been changed. The correct variable is now written in the CEL.
Item ID: 263485
Version: 11.00 Build: 157700
Version: 10.00 Build: 131739
    • eSignature CEL entries are not logged when setting values via RGM
      Description When setting values in the RGM directly from the SETVALUEKBD keyboard (via the control element Write set value), the eSignature dialogue appeared but the CEL entries were missing. This issue has been addressed and the CEL entries are now ...
    • eSignature can be bypassed by keyboard elements
      Description In the Recipegroup Manager (RGM) it was possible to bypass eSignature. The value was written instantly to the variable although the eSignature dialog popped up. The issue has been addressed and the value is written now to the variable ...
    • CEL category: CEL entries XML import of linked categories is not in correct order
      Summary In the zenon Categorization exported entries are not always imported correctly. This has been fixed. Description In zenon Categorization, CEL entries that are manually linked to categories are saved in the order in which they were added. ...
