User who has not defined a lock code can lock and unlock switches
In the Command Processing, a user without a defined Lock code can lock and unlock switching operations. This could only be prevented if a Lock code was set for all users. Since often, especially in the Active Directory environment, a large number of users would have to be configured, this solution is not generally applicable.
This behavior has therefore been changed. Users who have not been assigned a Lock code can no longer lock or unlock switching operations.
Item ID: 262312
Version: 11.00 Build: 126436
Version: 10.00 Build: 125767
