Problem:
[User Administration] Current authorization group 1-4 variables bits are not correctly set in Service Engine v10 32-bit when a user with authorization levels 31, 63, 95 and/or 127 logs in. As a result, the respective variable shows 'FFFFFFFF'.
Resolution:
This behavior has been resolved in Service Engine v10 32-bit in build 138660 or higher. Service Engine 11 (32/64-bits) and newer versions are not affected by this issue.
