Unhandled Exception with multitouch if button is configured as a Pushbutton
When using Multi-Touch, the Service Engine crashes if
a button is held while tapping somewhere else. This applies to Multi-Touch with
project property "Recognition" set to "Windows 8 and
later/Web Visualization Service". And it only happens with buttons where "Write set value" is set to "Pushbutton".
This issue has been fixed. Multi-Touch works as expected again.
To benefit from this
fix:
- Update your zenon Software Platform to the latest build of zenon 8.00 or higher.
Item ID: 179687
Version: 11.00 Build: 157700
Version: 10.00 Build: 144352
Version: 8.20 Build: 150600
Version: 8.10 Build: 160080
Version: 8.00 Build: 144579
Button as switch shows invalid state before a variable value is available
Summary A button element configured as a switch displays an invalid state in the Service Engine before a variable value is available. This behavior has been modified. Description When a screen is opened in the Service Engine, a button element that is ...
Platform Setup 11: Comparison Tool starts with "Unhandled UI Exception" popup error
Description When starting the Comparison Tool from the Startup Tool, an "Unhandled UI Exception" is displayed. The Comparison Tool cannot be started. This error has been fixed. To benefit from this fix: Update your zenon Software Platform to the ...
The SE reports an unhandled exception when closed while an evacuation to the Data Store is running
Summary The Service Engine reports an unhandled exception while evacuating data to Data Storage. This has been fixed. Description The Service Engine reports an unhandled exception if data is being evacuated to Data Storage while the Service Gateway ...
