unexpected shutdown of the zenon runtime when a SAP server program with a deleted zenon function linked to it is executed
It is possible to link zenon functions to SAP server functions. If this linked function has been deleted, then the property at the SAP server program will correctly show "function deleted". When the SAP server program is executed in the runtime, zenon tries to execute the already deleted function and thus stop working.
To overcome the described situation, zenon will now verify that the function still exists before executing it.
Issue Number: 34168
Fixed on Date: 4.5.2015
Versions: 7.20 0 BUILD 19742
Checklist: SAP Interface does not work
Time estimate: 30 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Checklist usage: #. [Quick ...
[SAP Interface] Values of export parameters of SAP function are not assigned to variables
Summary Two bugs occur in the SAP Interface: In the Service Engine, zenon variables are not updated correctly. And in the Engineering Studio, import/export parameters are swapped when importing RFC function configurations. These two bugs occur ...
when a function is linked to an SAP server program, it is not possible to delete this link any more
Summary When a zenon function is linked at an SAP server function, it is possible to open the function selection dialog for that property and click the "no selection" button. This should normally delete the link from the property so that no function ...
