Unexpected closing of RT if the SMTP/POP protocol password is too long.
If SMTP/POP protocol is used with Message Control it can happen that the RT is unexpected closed if the SMTP/POP email account password is too long(more than 13 characters).
The conversion of string data type which is used for passwords is now more flexible and can read longer strings.
Issue Number: 37641
Fixed on Date: 12.1.2017
Versions: 7.20 0 BUILD 35394 | 7.60 0 BUILD 36068
    • FAQ: How can I create long term Wireshark sniffs?
      In this example it will be used OPC UA protocol as example to show how to use and configure a long term Wireshark captures. This is the best option when troubleshooting a connectivity/network issue occurring sporadically and it is not possible to ...
    • FAQ: Send and receive Email via SMTP does not work
      Many email providers require the use of app passwords when accessing their services through third-party software. If you need to use SMTP or POP3 (or IMAP) to access your email, you will need to generate an app password specifically for that ...
    • How can I reset the password of a zenon Service Engine/Runtime User?
      Resetting a password in the zenon Engineering Studio can be essential for maintaining security and managing user access to your project. zenon offers two different methods to reset a password: one through the zenon Engineering Studio and the other ...
    • FAQ: I forgot my zenon Engineering Studio password, what is now? How do I am able to open my project?
      If a user forgets his Engineering Studio password, the administrator can remove the password and assign a new initial password. The administrator does not require knowing the password for these interventions. Recommendations: Create an administrator ...
    • Unexpected State detected for License dongles
      The license central indicates an unexpected state for a certain dongle if the state of the dongle - given in a license request or license confirmation file - does not match that one which is calculated by the license central. A reason for this can be ...
