Under Windows CE retain variables in zenon logic are not loaded.
Under Windows CE retain variables in zenon logic are not loaded when:
- stopping/starting from zenon logic workbench
- stopping/starting the zenon logic runtime
- compiling and downloading with stop/restart of the Project on the CE7 / ARM processor
This issue has been addressed by improving the behaviour the retain data file is read.
Issue Number: 36031
Fixed on Date: 7.3.2016
Versions: 7.20 0 BUILD 26944
FAQ: Windows CE not supported anymore with zenon! What are the main reasons and what do I have to consider? Is zenon not able to run on Windows CE anymore?
The support for zenon Windows CE Versions was frozen with the zenon Version of 7.20. This means that in any higher zenon version, the CE Version delivered with the Setup is a zenon CE Version of zenon 7.20. There are no more functional enhancements ...
FAQ: Update CE proceedure
zenon Logic: Sporadic data loss on retain variables
Description Retain variables were not loaded on startup because an invalid retain file was written when the retain file exceeded 256 KB with retain-by-name enabled. The issue has been addressed and the behavior is now as expected. To benefit from ...
