Under specific circumstances the zenon runtime may unexpected closed when POP3 server did not work as expected.
The issue happened when a SMTP or POP3 server did not send an opening message after opening the connection.
The MC SMTP dispatcher is now more flexible and can handle this unexpected behaviour.
Issue Number: 37381
Fixed on Date: 11.11.2016
Versions: 7.50 0 BUILD 33300
    • zenon Runtime closed unexpected under specific circumstances.
      Summary When duplicating a zenon project, which includes an WPF element created with our zenon 3D configuration tool, it may happen that the zenon Runtime close unexpected when opening the screen with the 3D WPF element. DescriptionWhen duplicating a ...
    • zenon Editor closed unexpected under specific circumstances.
      Summary It could occur that the zenon Editor close unexpected, when working with zenon 3D Configurator Tool and updating variables in the 3D Tool then reactivate at the zenon Editor another zenon project again. DescriptionIt could occur that the ...
