It may happen that the XML-import of alarm areas between two sub projects result in a wrong alarm class linking in the editor, so that the alarm areas class linking in the target sub project are shifted to the next alarm class, previously defined in the global/integration project.
An issue has been resolved so that the XML-import of alarm areas is correctly executed in the workspace.
Example: The sub project 1 alarm areas are linked to the alarm classes 1 and 2 defined in the integration/global project that also contains the alarm classes 3 and 4. The result of the XML-import of the same alarm areas in the sub project 2 shows these areas linked to alarm classes 2 and 3.
Issue Number: 35483
Fixed on Date: 3.11.2015
Versions: 7.20 0 BUILD 24121
