Under specific circumstances the Metering Point Administration ActiveX Control is not visible in the webclient.
It may occur that the Metering Point Administration ActiveX Control is not installed and registered by the webclient setup so that it is not shown in the webclient.
The webclient setup now installs and registers the Metering Point Administraton ActiveX Control so that this is visible in the webclient.
Issue Number: 34332
Fixed on Date: 29.4.2015
Versions: 7.20 0 BUILD 23281
Checklist: ActiveX control element
Time estimate: 30 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Screenshot and followed ...
Display issues with the Metering Point Administration when Windows display setting is not 100%
Summary Windows allows to modify the size of fonts and icons by setting 125% or 150% in Control Panel > Display. However, when selecting 125% or 150% the elements in the Dialog of the Metering Point Administration Wizard are not arranged correctly ...
relative counters created with the Metering Point Administration suddanly stopped working
Summary The Metering Point Administration allows creating relative counters which calculate the (e.g. energy) consuption within a specific time period based on the value of the linked absolute counter variable. However, the calculation of the ...
Multiuser projects are excluded from the Metering Point Administration. However, the the Metering Point Administration may still modify the project´s IMM database configuration.
Summary when starting the metering point administration with a multi-user project in the workspace, the wizard correctly identifies the multi-user project and informs that this project will not be available. However, during the check of the IMM ...
Metering Point Administration does not work with variables with Special characters in their names
Summary The Metering Point Administration creates some zenon logic code to calculate the relative values. However, if either the absolute value variable or the relative value variable has special characters (like ä, ü, etc.) in its name, then the ...
