Under specific circumstances the "current authorization group 1" variable is not set in the runtime.
The "current authorization group 1" system variable may not be set at the first login when a user logs in in the runtime if the login screen is executed as the project start screen.
An issue has been resolved so that the "current authorization group 1" system variable is correctly set in the runtime after a user logs in.
Workaround: To start the login screen via the AUTOSTART script.
Issue Number: 34250
Fixed on Date: 6.11.2015
Versions: 7.60 0 BUILD 36068
