Under specific circumstances a runtime client is not able to connect to the runtime server
With a specific network configuration with an integration project that uses a primary server and a secondary server and a sub project that uses only a primary server without redundancy, a client of the sub project may not be able to connect to the runtime server.
An issue has been addressed in the runtime where a specific configuration did not allow a runtime client to successfully connect to the runtime server. Now this limitation has been removed.
Issue Number: 36090
Fixed on Date: 15.3.2016
Versions: 7.60 0 BUILD 36068
