Under special circumstances, refreshing the IMM screen leads to an unintended shutdown of the zenon runtime.
It may happen that the Runtime closes unexpectedly when the user triggers a refresh of the IMM screen when there are multiple levels of hierarchy in the IMM structure.
An issue has been addressed where the runtime closed unexpectedly upon refreshing the IMM screen because of incorrectly releasing memory. After the fix, the refresh works as intended.
The issue was only reproducible in zenon 7.11
Issue Number: 31822
Fixed on Date: 14.5.2014
Versions: 7.20 0 BUILD 17768
SOT: Export of selected screen as XML leads the Engineering Studio to crash
Description If in a Smart Object Template (SOT) a screen is exported as XML, this leads to a crash of the Engineering Studio. This error has been fixed. Screens can be exported as XML in a SOT again. To benefit from this fix: Update your zenon ...
unexpected shutdown of the runtime when switching to an IMM (Industrial Maintenance Manager) screen without any elements
Summary When there is an IMM screen in a project which has no control elements in it, and a switch to this screen is executed in the runtime, then the runtime may shut down unexpectedly. Description When there is an IMM screen in a project which has ...
IMM Maintanance preview filters show no results
Description In the screen of the Industrial Maintenance Manager (IMM) type, all pending maintenance tasks are displayed in a list. When filtering for certain dates, tasks are not displayed, although they exist. This error has been fixed. Filters are ...
