Under circumstances the zenon runtime may not correctly recognize it is runtime server
Under specific circumstances the zenon runtime may not correctly identify the PC it was started from as the runtime server and attempts to start as a client instead of runtime server
An issue has been addressed in the zenon runtime where under specific circumstances a reverse name lookup did not result in the same name as a forward lookup. Now the runtime no longer performs a reverse lookup and the runtime correctly identifies the PC as the runtime server.
For "server1" and "server2" only a host name, with or without dns suffix, may be entered and not an ip address
On affected systems disabling IPv6 for the network adapter may act as a workaround to the issue where reverse lookup results in a different host name than forward lookup. With IPv6 disabled, the runtime may correctly recognize the host name for the runtime server
Issue Number: 34758
Fixed on Date: 10.2.2016
Versions: 7.20 0 BUILD 26116
Checklist: OPCDA Server
Time estimate: 20 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Do NOT use DCOM in combination ...
zenon runtime may stop responding under specific circumstances when using .WMF graphics
Summary When using .wmf graphics in combi elements, the runtime may sporadically stop responding on opening a screen that displays such .wmf graphics. DescriptionWhen using .wmf graphics in combi elements, the runtime may sporadically stop responding ...
Zenon Logic: OEM specific blocks and functions are marked as not supported after coverting a project from zenon 12 to zenon 14
Description When converting from zenon 12 to zenon 14, OEM specific functions and blocks for zenon Logic are marked as "not supported". This is due to a name change in the "Select" tab of the "Target System Configuration" dialog. "Logic Runtime for ...
