Trend diagram windows Manipulation using Mouse "No action" is affect by mouse click
In Extended Trend, the "Diagram window" is affected by actions with the mouse, even though these have been deactivated. This bug has been fixed.
In the Engineering Studio, the "Service Engine" properties for "Manipulation using mouse" have been set to "No reaction" in the Extended Trend screen for the "Diagram window". This mainly affects the properties "Drag with left mouse button" and "Drag with right mouse button".
However, if a click is then performed with the mouse in the Service Engine, the current trend in the "Diagram window" is stopped, although its status is "play". But it is expected that actions with the mouse have no effect.
This bug has been fixed. The settings for the mouse from the Engineering Studio are respected again in the Service Engine. Actions with the mouse have no effect if they have been set to "No reaction".
Item ID: 282344
Version: 11.00 Build: 242382
Version: 10.00 Build: 243056
