Trend curves are not displyed in the WebClient with the compatibility mode
Client cannot request historian data from Server below 8.20
Issue Number: 215639
Fixed on Date: 28.4.2020
Versions: 8.20 0 BUILD 66111
Screen switch function to Trend with option set: "show header in scan window in compatibility mode" do not show all curves
Summary When enable the settings "show header in scan window in compatibility mode" in the screen switch function to an extended trend screen, the first Curve is overwritten with the header in the scan window. Description When enable the settings ...
Scheduler in compatibility mode isnt working
Description Creating schedules does not work in compatibility mode. For example, Service Engine files (Runtime files) are created in version 7.60 for 6.22 SP1. The server is started in version 6.22 SP1, and the client is started in version 7.60. If ...
zenon crashes using Scheduler in Compatibility Mode
Description When using the Scheduler, the Service Engine (Runtime) crashes in compatibility mode. For example, Service Engine files are created in version 7.60 for 7.11. The server is started in version 7.11, the client in version 7.60. If an entry ...
ETM - Multi-select and multi-edit possibility for trend curves
Summary ETM allows multi select and multi edit for trend curves. Description From now on, both in the Engineering Studio as well as in the Service Engine, several curves of Extended Trend can be edited at the same time. To enable quick changes, ...
FAQ: How does COPA-DATA ensure the Product compatibility with Microsoft Operating System Patches? How can I get information about compatibility issues?
As a general rule, COPA-DATA recommends keeping the operating system current and installing the latest security updates. Check updates on your own system(s) before installation for possible interactions with the zenon Software Platform. The current ...
