translation error in zenon 7.60 and zenon 8.00
In the French language version of zenon, the string "Nouveau projet %OEM917" is displayed instead of "Nouveau projet zenon Logic". This translation error has been fixed. The correct expression "Nouveau projet zenon Logic" is displayed again.
Item ID: 181634
Version: 11.00 Build: 111398
    • Engineering Studio: Add Driver 'Siemens : S7 driver for S7-1200/1500' to Zenon Project - Error when starting driver
      Summary The S7TIA/S7 for S7-1200/1500 driver cannot be started. This issue has been solved. Description The attempt to add the driver S7TIA/S7 for S7-1200/1500 to a project fails in some constellations with an error message (Error code 0x8001011f). ...
    • Project in zenon Logic takes long time to compile and eventually Stops responding.
      Description A zenon Logic project takes a very long time to compile and may even stop responding. This can also affect the Engineering Studio. This mainly occurs when UDFBs are shared across several projects. This error has been fixed. Compiling a ...
