Topological interlocking should not be considered during REVISION and by alternate value or manual correction not changing the position of the switch.
In Command Processing module, the Topological Interlocking from ALC should not be considered: -when Response Variable (RV) has status bit REVISION. -in action types 'manual correction' and 'alternative value' if the operator sets the same value as RV already has, i.e.:
  • OFF --> Manual correction OFF or Alternative value OFF
  • ON --> Manual correction ON or Alternative value ON.
issue was addressed in check of topological interlocking.
the topological interlocking is not considered with action type setpoint input or set status.
Issue Number: 24700
Fixed on Date: 13.9.2011
Versions: 7.00 0 BUILD 0
