The Zenrt32.exe can´t be terminated via the Exit Service Engine Function, when the Login with Dialog Function is used
When the "Exit Service Engine" function is executed in a screen of the "Login with Dialog" type, the Service Engine crashes.
This behavior has been changed. Exiting the Service Engine using a function in the "Login with Dialog" type screen is now possible without errors.
Item ID: 261243
Version: 11.00 Build: 126436
