The zenon runtime (zenonrce.exe) stops working under CE6 on an ARM processor when 3S_V3 Driver is used.
When using the 3S_V3 Driver the zenon runtime stops working under CE6 on an ARM processor. An error message with text "Application ZENONRCE.exe encountered a serious error and must shut down." appears.
This issue has been addressed by changing the Byte alignment with CE on ARM processors.
The runtime behaves correct on CE6 when running on a x86 processor.
Issue Number: 31074
Fixed on Date: 27.1.2014
Versions: 7.10 0 BUILD 11355 | 7.20 0 BUILD 17768
