The zenon OPC UA server in the process gateway may close unexpectedly with a specific configuration when browsed by an OPC UA client in a particular manner
The zenon OPC UA server in the process gateway may close unexpectedly with an unhandled exception when a specific zenon project is used and an OPC UA client browses the OPC UA server address space in a particular manner. One situation where this could occur is when an OPC UA client reads the NodeId attribute of a datatype or the NodeId attribute of of a Variable type
An issue has been addressed where the OPC UA server in the process gateway would close unexpectedly with an unhandled exception when an OPC UA client would read specficic attributes with a specific zenon project configuration.
Issue Number: 36234
Fixed on Date: 31.8.2016
Versions: 7.60 0 BUILD 36068
    • FAQ: How can I browse an OPC UA Server using the zenon OPC UA Client Driver?
    • How to use certificates for OPC UA security
    • How to setup the zenon OPC UA Process Gateway with a self-signed certificate
      This article describes how to create a self-signed certificate for using it with the zenon OPC UA Process Gateway. For general information about certificate usage for OPC UA security, please refer to the article How to use certificates for OPC UA ...
