The zenon logic OPC UA server fails to start in case the directory structure for storing the application instance certificate does not yet exist.
When the zenon logic OPC UA server is started for the first time on a PC by default it will attempt to create a self-signed application instance certificate. In case the directory structure for storing the application instance certificate does not yet exist, the creation fails and the startup of the zenon logic OPC UA also fails.
An issue has been addressed in the zenon logic OPC UA server where first startup failed if the directory structure did not allow creation of the needed application instance certificate. Now the missing directory structure is also created when it does not yet exist.
As a workaround, manually a directory "PKI" can be created in the %CD_SYSTEM% directory and after restart of the zenon logic runtime, the zenon logic OPC UA server should now be able to create the necessary sub directories and the application instance certificate, needed for startup.
Issue Number: 33252
Fixed on Date: 17.11.2015
Versions: 7.60 0 BUILD 36068
How to setup the zenon OPC UA Process Gateway with a CA-signed certificate
This article describes how to create a certificate signed by a Certificate Authority (CA) for using it with the zenon OPC UA Process Gateway. For general information about certificate usage for OPC UA security, please refer to the article How to use ...
