The variable value is updated in the OPC UA server after a client has written the value, although the value in the zenon runtime is set to alternate value (ALT_VAL status)
When an OPC UA client writes a value for a variable that is set to ALT_VAL in the runtime, the value is written and updated in the OPC UA server although the value is not updated in the zenon runtime due to the ALT_VAL status.
An issue has been addressed in the OPC UA server in the process gateway. Writing itself is performed but the value in the OPC UA server now is no longer updated after the write request and correctly represents the value in the runtime for the variable set to ALT_VAL.
Issue Number: 29972
Fixed on Date: 24.10.2016
Versions: 7.60 0 BUILD 36068
