The variable identification in the archive revision filter dialog is not translated by the language switch function.
If you use a language switch function the keyword used in the variable identification in the archive revision filter dialog is not considered and therefore not translated.
The issue has been addressed and the identification is now translated properly.
Issue Number: 36440
Fixed on Date: 17.11.2017
Versions: 8.00 0 BUILD 46644
