The Unit in the CEL is not translated when RGM changes variable value
When variable value is changed by RGM then the Unit in the CEL entry about it is not translated.
When Unit is '@xxx@ ' the translation in the CEL is correct. But when Unit is '@xxx' the translation in the CEL is not correct. (see also KB item #177082).
The Unit text does not need to have a closing '@' any more.
Issue Number: 31457
Fixed on Date: 27.2.2014
Versions: 7.00 0 BUILD 17
