The temporary login dialog is opened several times for a combi element under specifc circumstances
When a combi element is configured as a push button or switch the temporary login dialog may open several times.
An issue has been addressed in the runtime at the combi element when used as a switch or push button. Now the behaviour of the combi element with temporary login is the same as with a normal button. If an authorization level is configured and the element is a push button, there is no temporary login, and the push button is not operated
Issue Number: 28008
Fixed on Date: 5.11.2012
Versions: 7.00 0 BUILD 4
