The system variable "Online printing on/off" has invalid status at start of runtime
The status of the system variable shows invalid until the switch online printing on/off is actually switched
The variable now shows a value of 0 on initial start of the runtime, and responds correctly when switched from 0 to 1
Issue Number: 24620
Fixed on Date: 17.11.2011
Versions: 7.00 0 BUILD 0
FAQ: How can I monitor and react on the communication status of my devices with zenon?
The system variable "teaching status" may not be updated in the Runtime.
Summary The system variable "teaching status" is not updated in the Runtime after reloading the project online when this is linked to a reaction matrix. DescriptionThe system variable "teaching status" is not updated in the Runtime after reloading ...
Checklist: zenHelpService cannot start
Time estimate: 15 minutes Please go through all the items in the following checklist. If necessary, confirm any information you cannot verify with the IT department before contacting your local COPA-DATA representative. If during the installation of ...
AddIn does not start
Check the Logs in DiagViewer. If it shows an ERROR in the GENERAL module which shows the exception: Scada.Internal.DotNetAddInExtension.AddInIntegration.Startup Cannot startup Add-In .NET Extension for instance id 'e1d3....'. Exception ...
Checklist: Process Gateway cannot start
