The system driver variable "wrong value for set value" is not always set in the runtime when entering an invalid value for a recipe variable of the Recipegroup Manager in the Recipegroup Manager screen
When entering an invalid value for a recipe variable in the Recipegroup Manager screen in the runtime using the current recipe value table, the system driver variable "wrong value for set value" is not set. When the value is changed in the legacy recipe value table, the system driver variable is set correctly.
An issue has been addressed in the runtime where invalid value input in the recipe value table did not trigger the "wrong value for set value" system driver variable.
Issue Number: 33343
Fixed on Date: 17.12.2015
Versions: 7.60 0 BUILD 36068
