The sorting in the recipe value table in the Recipegroup Manager screen in the runtime is reset after a recipe is saved.
When sorting for a specific column in the recipe value table in the Recipegroup Manager screen in the runtime, the sorting gets reset back to the default writing order when the recipe is saved.
An issue has been addressed in the runtime with the sorting of the recipe value table in the Recipegroup Manager screen in the runtime when the recipe was saved. Now the sorting is no longer reset.
Issue Number: 33816
Fixed on Date: 19.11.2015
Versions: 7.20 0 BUILD 24121
The sorting of the recipe value table in the Recipegroup Manager screen in the runtime changes unexpectedly under specific circumstances
Summary When selecting a recipe variable in the recipe value table in the Recipegroup Manager screen in the runtime and executing e.g. the screen specific function "read selected value", then change the sorting on a different column and executing the ...
The action for the Recipegroup Manager recipe variable may be reset under specific circumstances on saving the recipe
Summary When saving a Recipegroup Manager recipe in the Recipegroup Manager screen in the runtime, with a recipe table that does not display the recipe action column, the Recipegroup Manage rmay reset the configured action for recipe variables to "no ...
FAQ: When I activate the option "write synchronously" for the Recipegroup manager recipe, and I write the recipe, the recipe does not seem to be written properly and also the Service Engine does not close properly. Why is that?
When the option "write synchronously" is active at a recipe, when writing a recipe (sending values to the PLC) for each recipe variable a writing confirmation is requested to the driver. On a successfull write, the driver sends a writing confirmation ...
The recipe value table in the Recipegroup Manager screen in the runtime does not display any columns under specific circumstances
Summary When the Recipegroup Manager screen is opened in the runtime for a group that does not contain any recipes, the Recipe Value table is empty and does not display any columns. Also not after a new recipe has been created. DescriptionWhen the ...
FAQ: When I change something in the Recipegroup Manager via the programming interface in Service Engine, these changes are not updated in the screen. Why is that?
To understand this, you have to know that each time you access the RGM (Recipegroup Manager), you are working with a copy of the RGM data. So every screen that is opened in the Service Engine, has it's own copy of the RGM data. Also each instance ...
