The small webclient setup downloads the VSTA setup every time, even if the VSTA component is already installed
The small weblclient setup downloads some components from the internet during installation. One of these components is the VSTA setup. Even if the VSTA component is already correctly installed the small webclient setup will still attempt to download the VSTA setup. If the internet connection fails, the setup cannot be installed.
An issue was addressed in the small webclient setup where the setup did not check correctly if the VSTA component was already installed. Now the availability of VSTA is correctly checked, and the small webclient setup will no longer attempt to download and install VSTA when it is already installed.
Issue Number: 30116
Fixed on Date: 2.9.2013
Versions: 7.10 0 BUILD 7770
