The setting 'GetNameList on DO' from IEC850 driver in zenon is not included in IEC61850 Client in zenon Logic.
zenon driver IEC850 (Client) is supporing the optional setting 'GetNameList on DO'. The driver in zenon Logic - IEC61850 Client - does not have this option.
The driver configuration in zenon Logic now also contains the option 'GetNameList on DO'. It works like in IEC850 driver in zenon.
The optional setting 'GetNameList on DO' makes possible in Editor to online import variables and in the Runtime to associate with IED also when the data model (SCL-model) in the device does not fit the PDU size (biggest MMS frame) the IED supports.
The use of this option is a workaround we introduce in IEC61850 Client driver to make possible to successfully communicate also with some IEC61850 Servers with mismatches between data model size and PDU size. The use of this feature makes association - (re)connection - significantly slower. It does not influence the further communication (after association succeeded).
Issue Number: 32886
Fixed on Date: 17.10.2014
Versions: 7.11 0 BUILD 16009 | 7.20 0 BUILD 17768
IEC 61850 Client driver in Logic should have configuration settings BufTm, IntgPd, OptFlds like zenon iec850 driver has
Summary zenon version 7.20 has introduced in zenon IEC61850 (client) driver new configuration settings, but not in the Client driver in straton/Logic. The driver configuration RCB settings: Buffer Time, Integrity Period and Optional Fields should be ...
Interface settings for using an Ethernet port for Fieldbus communication in zenon Logic (e.g. ProfiNET)
When using a local Ethernet interface for Fieldbus communication in zenon Logic, you have to ensure that VLAN and/or priority settings (cf. IEEE802.1Q) are deactivated in the network adapter configuration. Therefore, go to the Network controller ...
When driver setting 'GetNameList on DO' is active, the IEC850 driver is not enabling Reports
Summary When the option 'GetNameList on DO' is active the IEC850 driver (Client) on Runtime start does not read the Report Control Blocks (RCB) from the affected device (IED). As consequence in the Runtime the driver does not enable (use) the ...
Renamed references do not rename zenon logic programs when updating the SOT
Description In a project references of a Smart Object Template (SOT) are renamed. When updating the SOT, zenon Logic programs are not renamed accordingly. The original names are still included. This behavior has been changed. When renaming ...
