The SE reports an unhandled exception when closed while an evacuation to the Data Store is running
The Service Engine reports an unhandled exception while evacuating data to Data Storage. This has been fixed.
The Service Engine reports an unhandled exception if data is
being evacuated to Data Storage while the Service Gateway (aka Service
Grid Gateway or IIoT Gateway) is closed.
This happens with large archives that take longer to evacuate to Data Storage.
This error can occur when stopping the Service Engine,
when reloading or when switching between server and standby.
The reason was that the component responsible for
transferring the data to the Data Storage was already cleaned up while a write operation
was still in progress.
This error has been fixed. The trigger for a shutdown
now has the following effect:
- No further operations are started.
- The cleanup mechanism waits until all pending
operations have been completed.
higher.
Item ID: 266441
Version: 12.00 Build: 180966
Under specific circumstance the zenon Editor closed with unhandled exception.
Summary The zenon Editor closed with an unhandled exception when undo a specific configuration of numerical elements. DescriptionThe zenon Editor closed with an unhandled exception when undo a specific configuration of numerical elements. Solution An ...
Summary The zenon Editor closed with unhandled exception. The zenon WPF Elements has an issue with the zenon Object at the WPF control. DescriptionThe zenon Editor closed with unhandled exception. The zenon WPF Elements has an issue with the zenon ...
