The SAP Interface does not support the data types INT1 and INT2
The SAP data types INT1 and INT2 are not handled correctly by zenon. Incorrect values are transmitted.
The described issue has been addressed. The SAP data types INT1 and INT2 can now be used in zenon. You may use variables of any numeric data type for such parameters.
Issue Number: 35160
Fixed on Date: 30.5.2017
Versions: 7.60 0 BUILD 36068
Checklist: SAP Interface does not work
Time estimate: 30 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Checklist usage: #. [Quick ...
[SAP Interface] Values of export parameters of SAP function are not assigned to variables
Summary Two bugs occur in the SAP Interface: In the Service Engine, zenon variables are not updated correctly. And in the Engineering Studio, import/export parameters are swapped when importing RFC function configurations. These two bugs occur ...
3S_V3 Driver : The Driver object type "Alarm variable" does not support the data types DINT and UDINT
Summary The Driver object type "Alarm variable" does not support the data types DINT and UDINT DescriptionThe Driver object type "Alarm variable" does not support the data types DINT and UDINT Solution The 3S_V3 Driver object type "Alarm ...
