The runtime server closes unexpectedly after several manual redundancy switches under specific circumstances
When in the runtime the function for redundancy switch is manually executed several times from a button that has the option "signature required" set, the server may close unexpectedly.
An issue has been addressed in the runtime where logging the user information in the event list for a button requiring a signature did not work correctly when the function that was executed was a manual redundancy switch.
Issue Number: 32177
Fixed on Date: 27.6.2014
Versions: 7.10 0 BUILD 13311 | 7.11 0 BUILD 13121
