The runtime may close unexpectedly when opening the Recipegroup manager screen with a report file that contains functions to retrieve other data
When opening the Recipegroup manager screen in the runtime with a .xrs report file as a parameter, the runtime may close with an unhandled exception if the report contains functions to retrieve data from other sources like the Events list.
An issue has been addressed in the runtime where opening a screen of the Recipegroup manager with a report file that containd functions not valid for the Recipegroup manager would cause the runtime to close unexpectedly. Now the Recipegroup manager screen can be opened however only data retrieved from the Recipegroup manager will be displayed. Functions that call data from other modules will display "-"
Issue Number: 31112
Fixed on Date: 25.11.2014
Versions: 7.50 0 BUILD 25796
The runtime may close unexpectedly when opening a screen.
Summary The runtime may close unexpectedly and produce an unhandled exception when it is executed a screen switch function. DescriptionThe runtime may close unexpectedly and produce an unhandled exception when it is executed a screen switch function. ...
When using a format file from the Report Generator (*.xrs) for the display of the recipe table in the Recipegroup Manager screen, hidden cells are not filled.
Summary When displaying a Recipegroup Manager recipe in the Recipegroup Manager screen in the runtime, it is possible to display the recipe table using a format file from the report generator, in order to have a custom design table. In version 6.50, ...
FAQ: When I activate the option "write synchronously" for the Recipegroup manager recipe, and I write the recipe, the recipe does not seem to be written properly and also the Service Engine does not close properly. Why is that?
When the option "write synchronously" is active at a recipe, when writing a recipe (sending values to the PLC) for each recipe variable a writing confirmation is requested to the driver. On a successfull write, the driver sends a writing confirmation ...
In a specific case the zenon runtime may close unexpectedly when opening a Variable diagnosis screen.
Summary If a project is engineered in zenon 7.10 editor and runtime files are compiled for an earlier zenon version, the targeted zenon runtime may suddenly close when opening a Variable diagnosis screen containing variables to display. If runtime ...
