The runtime closes unexpectedly when a user changes between data sources for a curve in the extended trend in the runtime
The runtime closes unexpectedly when a user manages to change between data sources for a curve in the extended trend in the runtime. Per definition, the data source for a screen switch function to the extended trend does not allow changing the data source in the runtime.
 An issue was addressed in the runtime where it was possible under specific circumstances to change the data source for curves in the extended trend. Now this is no longer possible.
Issue Number: 29231
Fixed on Date: 5.4.2013
Versions: 7.00 0 BUILD 10
