the prefix is added after using Replace text in selected column..." on straton variables "
Prefix is only used in the variable name.
Issue Number: 206679
Fixed on Date: 21.1.2020
Versions: 8.10 0 BUILD 63771
    • Prefix are added to the system variables in Smart Objects instances
      Summary Prefix are added to the system variables in Smart Objects instances Description Prefix are added to the system variables in Smart Objects instances Issue Number: 241489 Fixed on Date: 20.7.2021 Versions: 10 0 BUILD 87728
    • "Export CEL" function cuts off the Limit Value Text (by using CSV Export)
      In some cases the "Export CEL" function will cut off the Limit Value Text (by using CSV Export) by projects converted from older versions. To fix this effect you need to create a new "Export CEL" function in actual version.
    • Better management of comment (description) when editing variables as text
      Summary zenon Logic: When editing variables as text, a prefix is no longer necessary. Description When editing variables as text in zenon Logic, the description must be entered with a special prefix: $desc= For example: VAR b : BYTE ; (*$desc=My ...
    • StratonNG driver does not support variablenames without prefix
      Summary As the startonNG driver supports multiple connections without having a net address for identifying the connection it uses the variable prefix. So this prefix is mandatory when using stratonNG driver. But we also offer a setting to turn the ...
