The Outsourcing of SQL-Archives in MS Azure does not work - ZenonArchiveWorker reports error
Azure service ZenonArchiveWorker is not starting because it needs .Net 4.6.2 on Azure Windows Server 2012 R2 guest OS
change osFamily from 4 to 5 in ServiceConfiguration.Cloud.cscfg
Issue Number: 228344
Fixed on Date: 1.10.2020
Versions: 8.10 0 BUILD 69252 | 8.20 0 BUILD 69240 | 8.00 0 BUILD 69124
Evacuating archives to MySQL does not work
Description Evacuating archives to MySQL does not work. An unhandled exception occurs when creating tables. Cause: The problem is caused by an "unknown error" if CreateCommand fails when called after StartTransaction in the MySQL ODBC driver ...
Checklist: Smart Client does not work
SQL Azure Linked server does not appear in Linked Server-selection of the SQL-Connector
Description The linked SQL Azure server did not appear in the Linked Server-section of the SQL Connector. The issue has been addressed and the inked SQL Azure server is now available. To benefit from this fix: Update your zenon Software Platform to ...
Report Engine: it is not possible to display only evacuated AML- or CEL - reports (when using SQL connector)
Summary In the Report Engine, it is not possible to display only evacuated CEL reports when using the SQL Connector. This error has been fixed. Description In the Report Engine, when the SQL connector is configured for CEL only, all CEL queries fail, ...
Installation in zenon 11 error -2147217900
Fehlermeldung bei der Installation in V11 während des SQL Vorgangs: error -2147217900:failed to execute SQL string, error detail: The user does not have permission to perform this action. Diese Meldung erscheint, wenn bereits V10 auf dem Rechner ...
