The OPCUA32 client driver does not correctly take over the ApplicationUri in the ClientDescription in the CreateSessionRequest from the configured application instance certificate
The OPCUA32 client driver uses an empty string for the ApplicationUri in the ClientDescription in the CreateSessionRequest. This can lead to some OPC UA server rejecting the CreateSessionRequest with the error 0x80170000
An issue has been addressed where the OPCUA32 client driver does not correctly uses the ApplicationUri in the ClientDescription from the Application Instance Certificate in the CreateSessionRequest.
Issue Number: 33240
Fixed on Date: 3.4.2017
Versions: 7.60 0 BUILD 37399
