The OPCUA server in the process gateway is limted to variables of the startup project. The OPCUA server in the process gateway should be enhanced to support multi-project environments.
The OPCUA server in the process gateway now supports variables from all projects in the runtime. The variable selection dialog in the configuration of the OPCUA process gateway has been improved and supports sorting and filtering.
