The OPC UA process gateway closes on startup under specific circumstances
When a variable which is used for dynamic limits at an alarm variable that is used in the OPC UA process gateway, no longer exists (deleted) the OPCUA process gateway could close unexpectedly on startup.
An issue has been addressed where a deleted variable for a dynamic limit is correctly handled by the OPC UA process gateway.
Issue Number: 29890
Fixed on Date: 3.7.2013
Versions: 7.00 0 BUILD 11
