The OPC UA process gateway causes continuous high CPU load (80%) and increase of memory usage for the zenrt32.exe with a specific project
The OPCUA Process Gateway causes continuous high CPU load of the zenrt32.exe, and a steady increase of memory usage by the zenrt32.exe, with a specific project that uses a reaction matrix for ~3000 variables
An issue has been addressed in the OPC UA Process Gateway where under certain conditions the OPC UA process gateway created unnecessary connections to the zenon runtime for OPC UA alarm items.
Issue Number: 29903
Fixed on Date: 3.7.2013
Versions: 7.00 0 BUILD 11
    • How to setup the zenon OPC UA Process Gateway with a CA-signed certificate
      This article describes how to create a certificate signed by a Certificate Authority (CA) for using it with the zenon OPC UA Process Gateway. For general information about certificate usage for OPC UA security, please refer to the article How to use ...
    • How to setup the zenon OPC UA Process Gateway with a self-signed certificate
      This article describes how to create a self-signed certificate for using it with the zenon OPC UA Process Gateway. For general information about certificate usage for OPC UA security, please refer to the article How to use certificates for OPC UA ...
    • Checklist: Process Gateway cannot establish a reliable communication
    • Checklist: Process Gateway cannot start
    • How to use certificates for OPC UA security
