The OPC UA client driver does not allow configuration of the queuesize. A queuesize of 1 is always used, which may result in loss of value changes coming from the OPC UA server
The OPC UA client driver uses a fixed queuesize of 1, which may result in a loss of value changes coming from the OPC UA server.
The OPCUA32 OPC UA client driver is enhanced to allow configuration of the queuesize for monitored items.
Issue Number: 235299
Fixed on Date: 12.3.2021
Versions: 10 0 BUILD 83962 | 8.20 0 BUILD 82266
OPC-UA Server: DNS Name used in certificate created by zenon.
