The Web Engine shows problems and the message "HTML 5 Web Engine Connecting to server" during the connection to the server with the zenon Service Engine Connector. This connection error occurs only sometimes.
Cause:
A deadlock occurs in the Web Engine between value distribution and client connection when using the zenon Service Engine Connector.
Solution:
This connection error has been fixed. The deadlock no longer occurs.
- Update your zenon Software Platform to the latest build of zenon 10 or higher.
Item ID: 255841
Version: 11.00 Build: 112904
Version: 10.00 Build: 112170
