The Message Control event "SelectionChanged" for the Message Control screen view always contains an empty parameter, the actual selection is never included.
The event has now a array of Message Control message objects.
Issue Number: 28924
Fixed on Date: 20.2.2013
Versions: 7.10 0 BUILD 5560 | 7.10 0 BUILD 5560
Checklist: Message Control
FAQ: Message Control || VoIP message is sent but can’t be heard
In a VoIP message the audio file can use several codec formats for its compression. When a call is set up, then sometimes some target providers already play back the ringing to the call as an audio stream. This can be done in several or one specific ...
FAQ: Which IE version is used by the HTML screen? Which Plugins can be executed?
