The maximum amount of concurrent shared memory connections between zenon logic runtime and zenon runtime should be increased from 32 to 256.
The current maximum (32) of concurrent shared memory connections between zenon logic runtime and zenon runtime should be increased to 256.
 This issue has been addressed by changing the value of the variable responsible for the amount of concurrent shared memory connections from 32 to 256.
Issue Number: 38328
Fixed on Date: 31.5.2017
Versions: 7.50 0 BUILD 39729 | 7.60 0 BUILD 39532
