The "lengthen curve" functionality in extended trend does not work for archive data
When the property "lengthen curve" is activated for an archive data curve (on change) it does not work. The curve is not lengthened at all. If also the property "area display" is active the area is lengthened, but still the line is not.
lengthen curve was working only the line color was set to transparent. This is corrected now.
Fixed on 24.10.2012 , available from 7.00 SP0 Build 4
Issue Number: 27917
Fixed on Date: 24.10.2012
Versions: 7.00 0 BUILD 4
    • ETM: gantt curve is not lengthen if values are "on changed recorded"
      Summary If you display archive data with type of scan "on change recording" the gantt curve will not be lengthen until a value change has been performed. Gantt curve will be lengthen if: Type of scan is "cyclic scanning" Gantt curve will not be ...
    • Extended Trend curves not displaying when first curve is not active
      Summary When a Extend Trend screen displays more than one curve, if the first curve is disabled by the user (active off) and the remaining curves are still active, these also aren't shown >> Are also cleared from the trend. Note: this only occurs if ...
    • Extended Trend: In RT, it is not possible to add an additional curve
      Summary It is possible to add a curve in the runtime for the extended trend and change the data source under specific circumstances. DescriptionIt is possible to add a curve in the runtime for the extended trend and change the data source under ...
    • FAQ: How, where, why and when does zenon Service Engine save data?
