The jump element causes a validation error when the loop covers an OP (between parallel branches) which has a jump element in it aswell
Batch Control: When jumping within a branch, an error is caused in certain cases.
Cause:
When jumping within a parallel branch with preceding parallel branches, the stack validation does not work correctly.
This behavior has been corrected.
Update your zenon Software Platform to the latest build of zenon 8.20 or higher.
Item ID: 249906
Version: 10.00 Build: 98635
