The interlocking "Area with undefined status would increase" in some Topology does not work correctly with new ALC algorithm "Input takes priority"
The topological interlocking "Area with undefined status would increase" in some Topology networks does not work correctly with new ALC algorithm "Input takes priority".
The check for "Area with undefined status would increase" is improved now.
Fixed on 07.05.2012; available from 7.00 SP0 Build 1;
Issue Number: 26762
Fixed on Date: 7.5.2012
Versions: 7.00 0 BUILD 1
    • FAQ: How can I monitor and react on the communication status of my devices with zenon?
    • Interlocking conditions in actions are only considered with Topology Module license.
      Summary When using user-defined interlocking conditions in actions of Command Processing, the conditions are not considered with Energy Edition license. They are only working if you have licensed the Topology-Module (advanced ALC) too. ...
